Rev. Po-Jay
Member
I use the BW widget on my homescreen and it works very well with ICS, other than one nagging issue... I have the temperature in the notification bar. When you pull the bar down, the sun/moon is there and its supposed to show the temperature, city and forecast in notifications, next to it. The font in black on a black background, so you can't see anything... Any idea how to change the background or font on the notification bar or within the widget?
Also, Thank you Motorola/Verizon for separating Slide Lock and the Pattern Lock! It hasn't been separate since Android 1.2 (on my original Droid). One of my favorite things about ICS!:smokingsomb:
