Help Beautiful Widgets Temp Error?!?!
RayKinStL
Member
Anyone else experiencing an issue with the temperature being wrong in beautiful widgets? When I look at it, it correctly tells me the L:28 and H:48 for my area, which matches what the stock weather widget says. However the current temp says 23 degrees. This doesn't make sense for 2 reasons. First of all, it doesn't even fall within the high/low scale, and secondly the Google Weather and News widget says the temp is 37 degrees, which is MUCH MORE accurate. My location information is correct and I even tried a refresh on the widget, but that incorrect information continues to be displayed. Anyone else having similar issues or know a solution for this?
Thanks!
