I downloaded beautiful widgets on my droid 2 global. I went through all of the setting and selected skins but when I leave the app, nothing changes. What am I doing wrong?
What skins did you change? I change skins based on what background I'm using. If I using a light background I use a skin with a black font and vice versa.
Make sure you select the skin for the version of the widget you are using ex Home weather clock, or small toggles. Then, make sure to hit save and apply.
