Apps Beginner coding help
chodien
I'm writing an android program for adding task and deleting task in listview. I've add an onClickListener to the delete button so it can delete the task. However I was told I should not have the listener in the adapter violating mvc. So can someone help me how I can remove a task in my TaskListItem class. I got the method removeTask() in the adapter, but don't how I can use it in the TaskListItem class. Thanks.
Code:
public TaskListItem(Context context, AttributeSet attrs) {
    super(context, attrs);
    mContext = context;
// locate the textViews
protected void onFinishInflate(){
    super.onFinishInflate();
    taskName = (TextView) findViewById(R.id.the_task);
    resp = (TextView) findViewById(R.id.resp);
    prio = (TextView) findViewById(R.id.prio);
// getter and setter for the bin button
public ImageView getBinIcon() { return binIcon; }
public void setBinIcon(ImageView binIcon) { this.binIcon = binIcon; }
public Task getTask() { return task; }
// set the text for the textViews
public void setTask(Task task) {
    String currentResp = resp.getText().toString();
    String currentPrio = prio.getText().toString();
    this.task = task;
    taskName.setText(task.getName());
    resp.setText(currentResp + task.getResponsible());
    prio.setText(currentPrio + task.getPriority());
    binIcon = (ImageView) findViewById(R.id.bin_icon);
    binIcon.setOnClickListener(new View.OnClickListener() {
        public void onClick(View v) { /** delete task */ }
Code:
public class TaskListAdapter extends BaseAdapter {
private ArrayList<Task> tasks;
private Context context;
private int position;
public TaskListAdapter(ArrayList<Task> tasks, Context context) {
    super();
    this.tasks = tasks;
    this.context = context;
public int getCount() { return tasks.size(); }
public Object getItem(int position) {
        return (null == tasks) ? null: tasks.get(position);
public long getItemId(int position) { return position; }
 * set the view
 * set the task and bin icon from TaskListItem
 * add listener bin icon, when clicked the a task is removed from the array list task
public View getView(final int position, View convertView, ViewGroup parent) {
    TaskListItem tli;
    if(null == convertView){
        tli =(TaskListItem)View.inflate(context, R.layout.task_list_items, null);
        this.position = position;
        //tli.setBinIcon((ImageView) tli.findViewById(R.id.bin_icon));
    else { tli = (TaskListItem)convertView; }
    tli.setTask(tasks.get(position));
    tli.getBinIcon().setOnClickListener(new View.OnClickListener() {
            tasks.remove(position);
            notifyDataSetChanged();
    return tli;
public void removeTask(){
Maybe I'm missing something, but what is violating MVC? There are two jobs to be done; to remove the item from the View and to remove it from the Model. Each can do its part of the job; it's just a matter of how you inform them, which I guess is up to the Controller to do.
Outside of Android I have the misfortune to work with some nasty injection-based stuff (personal view; I didn't write it) where the View has no access to its own Model. Instead, somewhere down in a Spring framework the GUI components get updated by a model that traverses the component tree looking for data attached to the components. Wholly over-the-top for what's actually needed, but that's what happens when you hire contractors. Point is, I wouldn't be too religious about Design Patterns; what matters is a) does it work and b) can it be maintained.
