Hi guys,
I'm new to android and java coding, but trying to learn. I have several years of experience in other languages though.
Anyway, I was just trying out a hello world app, and have run into problems.
I'm simply trying to display an image by using an ImageView defined in xml. This is my code:
main.java:
main.xml:
The code compiles fine but I'm getting a force close when running, I think the reason is a nullpointerexception at this line:
final ImageView image = (ImageView) findViewById(R.id.img1);
If I remove it, the app runs fine. img1 has the src of an existing file, icon.png which is located in res/drawable. Not really sure how that part works, though since the extension is not included in the code (it's set automatically by eclipse).
Help is really appreciated!
main.java:
Code:
package com.hw;
import android.app.Activity;
import android.content.res.Resources;
import android.graphics.drawable.TransitionDrawable;
import android.os.Bundle;
import android.widget.ImageView;
import android.widget.TextView;
import android.view.View;
public class main extends Activity {
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
setContentView(image);
TextView tv = new TextView(this);
tv.setText("Hello, ffs Android");
setContentView(tv);
main.xml:
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<TextView
android:layout_height="wrap_content"
android:text="@string/hello"
<ImageView
android:id="@+id/img1"
android:layout_width="wrap_content"
android:src="@drawable/icon"
</LinearLayout>
rientation="vertical" >
