Help Behold 2 odin isn't working for me
stef1645
Download Start...
<0> Create File...
<1> StartThread Detected : 1
<2> StartThread Detected : 0
<3> StartThread Detected : 0
<4> StartThread Detected : 0
<5> StartThread Detected : 0
<6> StartThread Detected : 0
<7> StartThread Detected : 0
<8> StartThread Detected : 0
<1> setup connection...
This is where i'm stuck at. I left it for an hour an it still didn't move. I tried install the drivers over again and go through the root process but i messed up rooting. I was at the almost finished in cmd prompt at " adb install superuser.apk" but the file couldn't be found. So i typed in reboot, which turned my phone off. Now i can't even get it to turn on. It lags at "Android" logo. Is my phone done. Is there anything i can do.
I think i have the root done be not my phone lags bad. Takes about 30 seconds ot more to perform a simple action and i still can not get pass the setup connection in odin.
i got it working. I had to use another computer though. I don't really understand why it didn't work on mine. May have been a driver issue.
I had the same problem for ages until finally I actually read the instructions
you press and hold: Volumde down + OK button (not send button) + End
I was doioing volume down + SEND + END which put phone in "Recovery Mode," a very different thing from " Download" mode. hope this helps some ppl
