Behold 2 w/ Galaxy ROM USB Issues
A few weeks ago, a friend and I went through the process of making my Behold 2 think it's a Galaxy (thanks to all who made that possible!). Now, after having played with it for a while and the lack of vibration annoying me, I've decided to try to use Odin to revert to the standard Behold 2 ROM.
This is where my problem comes in: I am unable to get any USB Driver for the phone to work. In USB Debugging, out of debug, in download, or any other way I can think of. The phone just doesn't seem to want to connect. When not in USB debugging mode, I can get my computer to recognize the SD card and access files, and it'll charge, but, I can't get any other USB functions to work.
I'm not sure if this is a driver issue or if this is an issue with the phone itself.
I'm running Windows 7 Pro 64bit.
Could someone walk me through troubleshooting this?
The only way my computer will see the phone in those modes is when I reboot I press f8 then turn sign drivers off. I have downloaded every driver that was recommended for W7 and still didnt work until I did this. I am a noob, and dont know too much, but this is how I got around it. Hope its that easy for you.
Nope, doesn't work. I just tried it and the drivers do not install. The computer seems to recognize the phone, but, the drivers fail to install.
I had to Manually install the Driver's via Device Management in windows 7 for mine to work. Hope that helps.
Didn't work for me. There's a couple of "Unknown Devices" in my device manager that I can't seem to get any drivers installed for.
Did you right click them, go to properties, I think advance properties, update driver/ driver details (or something in that area, I dont have my laptop).
You have to path the driver to where the drivers folder is located to allow it to find them.
I had the same problem, same operating system.
I ended up using this:
MEGAUPLOAD - The leading online storage and file delivery service
It will make your computer think your phone is a galaxy, and everything will work just fine. Give it a try and let us know.
