Best Android to PC remote
xinn3r
Member
Title says it all? What do you guys recommend?
And if you know a great PC to Android Remote, can you also recommend the best?
It's best if I just have to install it, meaning I don't have to set alot of things,
maybe just connect to the same Wi-Fi network and Voila!
I just installed the free version of Unified Remote and all I can say is WOW! This thing does everything! The paid version seems to give several more remotes. THe only one I can think of that would be sool to have woulr be for Power Point, but I rarely use PP. Happy with the free version for now.
The only pain was that it needs TCP port 9512 to be opened and it was not automatically added when I installed the server software on my computer, I had to manually add the port rule to the Windows 7 firewall.
