Best apk + data backup application?
apple2005
I have been using go backup pro since long time but recently it started crashing always. So I want to switch to another one. But I want that the application should be able to backup both DATA AND APK. If it backup contact and sms will be an added benefit.
Thanks in advance.
Thanks everyone for help. I think I will settle with Titanium, as my device is rooted. But I need some clarification. Is it backup applications with data or only apks? Because when I want to backup, it gives options like applications, system data or applications plus system data? What is meant by applications plus system data? Isn't it the same like backup in recovery? Thanks.
For individual apps, Titanium backs up the app and data. If you restore it can restore app only, data only (if app already installed) or both.
For batch operations you can back up categories, such as user apps (which will include their data), system data, etc. This differs from a recovery backup because it's still backing up a lot of separate files rather than making images of the relevant partitions, and because you can't use it to replace a ROM, just restore apps and their data when the ROM is working (and conversely, you can't restore an individual app or its data from the recovery backup, or at least not using recovery - Titanium Pro can actually extract this from some recovery backups).
