That's how Juice Defender saves battery life--by turning off data connections when your screen is off.Ive tried juice defender, found it messed with my data. it would turn it off completely sometimes.grr
i was hoping the ICS update would improve it but not in the slightest![]()
Easy Battery Saver
Easy Battery Saver - See here
That was the best battery app I've ever used and it actually works amazingly well. On my SGS2, with the stock battery, after installing / customizing this app, I got around 3 days from 100% battery to 10%.. and this was not just a one time event. I've tried this app for close to a month now.
Check it out. It's really worth it. Very easy to use and customize.
PS., and no, I'm not involved with this app in any way other than being just a user and so I'm not trying to market this app.
It's not about what you can and can't do. It's about automating the process. With a widget, you have to actually press it to turn stuff off and on. With JD, it just does it for you. It's about convenience and automation, not additional functionality.I tried JD, but found it did nothing I couldnt already do with stock widgets, like turn off wifi, data, sync etc.
http://androidforums.com/android-ap...explained-security-tips-avoiding-malware.htmlHow would one find out what apps are malicious?
