TRS-80
Anyone found a good car mount for this Samsung Indulge? Or a good quality universal type mount? This is what I am looking for (in order of importance):
window / suction mount - I'm pretty sure this is what I want, I'm thinking so the phone can get good GPS signal? Right? Unless you guys educate me otherwise...
sturdy / well built - Nuff said. Don't want something that will get floppy after a while.
able to rotate horizontal or vertical - For nav/map mode (horizontal) or other usage (vertical).
easy to get phone in and out of mount - I don't want to be wrestling with the dang thing, I am in and out of my truck a lot.
adjustable - By adjustable, I mean the phone "grippers." So I can use it with current case (or any future, possibly larger case). I suppose I also mean adjustable up, down, left, right, etc. but I suppose they all do that.
can plug in charger while phone is in mount - We all know how this phone can suck the battery. This is not a deal breaker for me however, as I have a Dremel and know how to use it, so I could always make my own opening.
I think that would be it for now. If I think of anything else I will add it here. After I order whatever I end up deciding to order, I will report back here with my findings.
