I use this case and i can tell you it makes it bigger but its also much easier to hold now and it is pretty much fall resistant now.Just bought a "ballistic" case like this one: will report on it once it arrives. Using a basic silicone slip on now.
I like the looks of the skinomi sheilds, but looks like they only protect against cosmetic damage. I'm using the silicone cover from LG and like it alot. Although not as protective as some other cases, it's not bulky at all, which I like since I carrry my phone in my pocket.
I have ghost armor on the screen and the Verizon rubber case on the rest. No complaints.
I've done hard cases on other devices with mixed results; they either shatter/crack or last forever. I'm pretty happy with the rubberized one I got @ vz, though.
You mean the screen image/quality? It doesn't diminish the quality that much for average applications and images. BUT, if you're watching HD movies or Netflix, you'll see some wavy lines. It's like if you were to take plastic wrap and put it over your screen. Honestly, it's not that bad. It's not as clear as the VZ/stock protector, but it's rubberized, so fingerprints simply don't appear. Seriously, I've maybe cleaned the screen 3 times since I had it put on, whereas I had to clean my VZ protectors several times a day.What have you experienced with the so called "orange peel effect"? I was looking at these and was definitely wanting more info about this...
On a very unrelated note, certain member's names are listed as premium I was just wondering what exactly that means?
I ordered a Body Glove slide on hard case. I don't have it yet, but I am excited for it to arrive.
