Best Case for Zmax Pro
Got one of these for the ZMax Pro. Works great and phone lays flat. I bought the balck & CLear one. Now I want the clear one...
Matt
How's the stretchiness? I usually don't care for TPU because it's too soft and floppy. I prefer one-piece slim poly cases but I can't find any for this phone.
It's only flexible enoug to fit the phone. It fits just right. The lip does not roll back like on a case of this type that is too flexible. I'm liking mine a lot.
I have the clear with black edges. I just ordered the all clear one as well to see how it looks. The case is tick at the corners and has a backing trim that keeps the phone flat when put on a flat service. They are cheaper on Amazon than ordering it directly from the manufacturer.
I have the same case as Raff and it's worth the 30bucks. the rubber is nice and sturdy and the second layer is firm and solid. I work in a warehouse so I wanted something that can withstand concrete and this does the trick.
Luck is kinda involved because I don't have anything protecting the screen but for the most part if my phone were to drop on its sides it will live to see another day.
I have the Poetic case posted in the OP and really like it. I also bought the dual layer case (when I bought my phone) sold in the Metro stores. I was surprised it was a solid case.
I just ordered a different case (for my Zmax Pro) from Wish.com mainly to test out Wish
I have the same case as Raff also. Works great except after several months of shoving it in and fighting to pull it out of front pockets the corners of the outer shell have cracked and come apart.
Matt
Hi Matt
I have the clear on my zmax pro and am sorely disappointed so I am order in the black and clear.  The clear does not look right for the device!
