You will not find one as stable as backside... that being said cm9 and aokp both are great builds. I run aokp and have for 2 weeks... and I'm a flashaholic! It has a ton of customization. Just read the op first. It's all in what you want.
-Download goomanager from the market,
-in the app, goto browse all files, then goto /devs /tdm /roms /quattrimus /nightly /vm670, and choose either CM9 or AOKP.
-Don't forget to grab an ICS gapps.
-Then reboot to recovery, wipe/format everything except sdcard
-flash the quattrimus you downloaded, will be llocated in the goomanager folder,
-flash gapps,
-reboot,
-enjoy.
Its recommended that you create an ext partition on your sdcard of at least 512mb or 1gb. There are guides in the forum that explain how to make one.
I've been running Quattrimus CM9 for about three weeks now and I love it. Very stable with exception of a BT bug that reboots the phone when you turn BT off but even that should/could be fixed soon.
