Best Jellybean 4.1 ROM?
GalaxyS24g
I've been using b_randon's ROM for 3 months. I love it. Thinking about trying the Midnight Rom, but I was wondering about a 4.1 ROM to avoid the Bluetooth issue with 4.2 and the Wiimote.
Does anyone have any suggestions? Preferably CM...
It's not a big deal... I have Sixaxis, but would also like to use my wiimotes. (I only have 1 ps3 controller and 3 Wii controllers)
I'm using Jellyverse ROM which can be found on XDA. Been using it for the past few months and haven't even thought about switching ROMs. Everything just works and it's 4.1.2. I should note though that it is a TW ROM (but looks are very customizable in the settings).
which ROM,and a link plz i'd like to check it out.
TBH, I've tried out 4.2.2 roms (Cm10.1, jellyverse, etcetc) and I ALWAYS have had issues with phone calls. The mic would just...cut out. I've tested this with several people and the same thing happens
Thank you. Jellyverse looks great. I'm going to try it out.
Thanks to everyone else too. I was thinking about gb28 but not too excited about it.
Only problem I've had (with b_randon's rom) was occasional echo complaints from whoever I was talking to, but I think that was because of call recorder app that I had. Once i uninstalled no more complaints.
I've been on b_randon's CM ROM since he released it and thought it was fantastic. Batt life started out great, but declined after a couple months so I decided to try the GB28 and have been disappointed. I was about to go back to CM, but I think I might try jellyverse, too.
What modem did you use or download from the link? I'm not sure which one to download. (It won't let me quote apparently) so @notebooko
