Apps Best library for 2D android game development?
There really isn't much out there for 2D games, unfortunately, your best bet is AndEngine, but I don't really like that library for multiple reasons. That's not to say it won't fit your needs though.
I've just started using Libgdx and I'm really liking working with it so far. I've checked out AndEngine in the past and got deep enough into it to discover that I didn't want to use it.
I was under the assumption that libgdx was focused more on 3d games, but I haven;t used it in a long time. Glad to know its easy to make 2d games with it now too. =)
AndEngine is only for 2d games? I'm going to use libgdx because I can make games for Android, desktop and HTML. Sounds Good.
Thanks.
