Best Media Player?
I just started using poweramp, and I really like it... You can try it free and then upgrade if you like it.
Poweramp is the best, but you can alsso try winamp. Both are available in the market for free, for trial of course. If you want full version buy it from market or try google. :-)
Dont forget to hit thanks if i helped you!
sent from my rooted gingerbread GT-B7510 using tapatalk
Nothing for 15 days.
I'm not even sure what all the paid version does, but I don't mind buying an app that works well for me. YMMV. :)
I really don't want to pay for any apps pretty much period. I saw some popup for a second about 2 weeks or something but accidentally hit OK and I don't know what all it said.
Poweramp allows you to use it even after the 15 days trial, with all the functions. But you will get annoying popups telling you that ur trial is expired. Just hit ok everytime nd u r gud to go. Else, buy it.. :-)
