I've tested a few such as Waze, google maps and I have yet to find one that offers the following. Most if not all Navi software determines which roads and path to reach a destination. It may change somewhat if you select options such as fastest, most direct, 4 lane only and so on. You can't select a different route and end up at the same destination. An example would be a destination of Phoenix from Des Moines, IA. The Navi app may have me driving through Utah and Colorado. But let's say I wanted to drive through Liberal KS, Dalhart TX then Tucumcari NM without having to reset a route each time a reach one of those cities? I should be able to determine my direction with ending up at my same destination.
elchucko;[URL="tel:6302138" said:6302138[/URL]]I've tested a few such as Waze, google maps and I have yet to find one that offers the following. Most if not all Navi software determines which roads and path to reach a destination. It may change somewhat if you select options such as fastest, most direct, 4 lane only and so on. You can't select a different route and end up at the same destination. An example would be a destination of Phoenix from Des Moines, IA. The Navi app may have me driving through Utah and Colorado. But let's say I wanted to drive through Liberal KS, Dalhart TX then Tucumcari NM without having to reset a route each time a reach one of those cities? I should be able to determine my direction with ending up at my same destination.
I tried a lot of these apps after Google messed up Google Maps/Navigation with their "upgrade." I concluded even with its deficiencies, Google Maps is still the best, based primarily on traffic data and the ability to toggle between close up and wide view maps, and also the ability to work with Chrome to Phone to transmit addresses from your computer (which surprisingly, not all Navigation apps can do).
It is starting to integrate some Waze features, such as incident reports. I'm not really crazy about that, but haven't tried to find a way to turn that off.
I gave Google Maps a try last month after using Waze for almost a year. I absolutely hate it. I have to reset the zoom level every time I use it. I hate the auto zoom that is set as the default. I cannot see the traffic very well at all. I cannot even use the Navigation view without entering a destination. Often I want to drive and use the Navigation view to check the traffic ahead. I was going to try it for a week, but gave up after a day and went back to Waze.
I'm using the older version of Google Maps Nav. and this is my first choice for Navigation. I use CoPilot V9, which has way more customizable features, then Google Maps Nav. Copilot has this feature were it will give you 3 routes to choose from, to the same destination, or you can create/drag your own route. (You can even add POI's while in route.) It does have live traffic updates, which cost $9 a yrs. The only thing I would change, is more attractive maps, like Google maps. Nothing beats Google maps when it comes to appearance, details and 3D images of buildings.
