Best podcatcher?
widehead
Any up-to-date info on a quality free podcatcher for Android?
Missing the simplicity of Symbian in this regard. And that is saying something.
well, that depends, update since when?
Personally, I use google listen & have been perfectly happy with it.
It took some getting used to at first (I was switching from itunes, which I still kinda miss for podcatching with my old ipod touch).
My biggest annoyance is that I sometimes miss podcasts because they disappear from my fresh items list before I listen, but this is easily fixed by manually adding them to my queue.
I use HAPI Podcast which is pretty good, if a feed is not found by search you can add manually and you can set to download only when connected to wi-fi. :)
I use MyPod (there's a free version which is pretty good)
It's not the simplest of Podcast apps, but it works nicely.
I also miss the awesome Nokia Podcast app, which I think is about the only thing I do miss from my Nokia Days...
I tried most of the free ones, but in the end i bought DoggCatcher and it is well worth the money if it is your first purchase :)
Tried most of them but nothing I've found yet has stopped me using itunes and synching over wi-fi to the phone with iSynchr.
I use carcast. Simple, works well, downloads pods and then is offline.
Also, I had a problem manually adding a podcast. Emailed the developer and had a response within an hour with the podcast added to the list of available downloads. Very impressive.
