Help Best rooting method?
miseryguts
I've just bought a 16GB Huawei MediaPad M2 10" & would like to root.. I've got the One Click Root app installed on my PC is this OK to use or is there a better method?
Well One Cick Root isn't any good, is there another option?
Is that something a complete novice could(should) attempt?
The bootloader unlock is pretty straightforward. Off the top of my head i do know of a way to get the bootloader unlock code without waiting etc.
Is this OK for a novice.... We all started as novices, it really depends on how comfortable you are with adb & fastboot commands. To me they're easy to others maybe not.
Thanks, but I think I'll leave it alone.. not confident with the commands, hopefully there will be a one click solution before too long.
