Best running app?
Joshbear
Member
So what does everybody think the best app to keep track of runs is? I'm currently using CardioTrainer, but I recently came across the Nike Running app and it seems to have a lot more features that are geared specifically towards running than CardioTrainer does. How is the Nike app and what are some other good ones that people like?
Thanks!
Hi, Joshbear! Yes, I heard that Nike running application has a lot cool and awesome offered features. The application lets you keep track of your activities throughout the day and compare the results over a period of time. It automatically saves you runs and activity to let you see your improvements. Also, Nike application would make you set your goals and helps you achieve them one at a time. Furthermore, you can access coaching tips and tricks from their world-class coaches for better performance. Moreover, the application helps you look for brand new places to run, offering games, rewards and other ways to help you test your limits. The application also allows you to describe your experience each day, challenge your friends so that you get more motivated and lets you share your success!
