Best Screen Protector for MyTouch 4G
Tredigity
I'm getting a MyTouch 4G for Christmas, and I want to get a screen protector to protect myscreen. I've read some good things about Xtreme Guard screen protectors, but most of that came from E-bay sellers.
I was wondering what type of screen protector you folks would reccommend.
I got the standard one from the T-Mobile store the fit isnt what I expected or would like it to be, its a little bigger than the screen itself. My idea of the perfect protector would be one that covers the entire glass or the entire screen and nothing more. The official mytouch one seems to be in between of them. But I do think its worth it and still have it on so I guess I like it.
i got mine with my cases and i also bought the pack from the store. i guess its ok! i usually get zagg screen protectors.
I tried the protector the tmobile store sold me but i didn't like it.. the edges started bubbling up. So I went to the XO Skins kiosk in the mall today and had them put a screen protector on. So far so good. They are cut to fit the phone perfectly and as long as the person at the kiosk knows how to apply it properly it works great.
FYI I'm not too happy with the Ghost Armor one I bought. Kind of a rip off for $20 installed at a mall kiosk. The only good thing is for as long as they are in business they will warrant it and fix anything wrong with it.
When I used it in conjunction with a silicone case, the corners do bubble and you have to take the case off and wipe it down again.
I found the best case on amazon. Its an argyle hard gel and comes in different colors. Its like a gel skin but dosnt stick to your clothing when taking it and out your pocket. Amazon has alot of stuff and deals.
Best skins ever, cheap and just as good as anything else out there. Not to mention that the full body skin includes a film for the camera lens.
Without a doubt clarivue and SGP make the best screen protectors on the market. At this point clarivue is the only one that makes one for the MT4G. I have one on and I love it.
The issue with both of these is that they are not easy to put on. It requires a steamed bathroom to clean the dust in the air, strict removal of all dirt and dust on the screen and patience.
Something like zagg and invisible shield are easy to put on and work fine, but if you want the best you will have to work a little harder to put it on.
