Optimus_User
What's the best screen protector for the S3? The one I bought from T-Mobile is horrible. I bought a Zagg INVISIshield without realizing I needed to spray a ton of liquid ONTO my phone.
Zagg is too rubbery. I use Spigen Curved crystal and do not even notice it being there.
This is also something I wanted to say, but had forgotten to mention. It looks like an orange peel. And, also, it doesn't matter if I spray the screen protector, would it not still make contact with my phone?
Thanks for the suggestion of the Spigen. I'll check it out. Do I need a spray?
1. Do not worry about the spray, it is not going to do any harm as you are not going to use a lot. Just spray some onto the protector so you can move it around and adjust.
2. No spray needed for the one I got from Spigen.
3. I have had Zagg before, but it is much inferior to the Spigen I have now.
I've heard good things about Spigen. I'm definitely going to have to pick one up. Thanks for the recommendation.
