Best sub
Both are great devices, I love my Prime and N7, but the latter is the best bang for your buck. Does your SGS2 run stock Jelly Bean? It really does make for a great update in terms of software and speed.
If you really want a 10", I'd take a look at the Transformer series in addition to the GTab 2.
Thanks for that.
Not running JB on my phone.
The N7 was just too small for what I want. Play a lot of web based games and need the size.
Transformer series look good but can't get them within my budget :(
How about a used TF101?
If you can get a Gtab 2 10.1 with ICS out of the box, it might be your ticket. I'm just slightly wary of Samsung tablets after my experience with the initial 10.1 (and with reviews on the Note 10.1 being pretty subpar).
Yeah. Gtab2 10.1 comes with ICS now in Uk.
Had a play and I am happy with it.
Just wanted to make sure I wasn't making a huge mistake but I think it is a toss-up between that and the Xoom 2.
Want to go brand new as it is a birthday present from the wife :)
Gotcha. I don't know much about the Xoom 2 other than its a modest upgrade from the first one and has Motos skin on it rather than being a stock device like the first.
Between the two, I'd recommend the Samsung.
