Best Torrent Client?
Sorry if this question has been asked but what I'm looking for is this:
A bitorrent client that will download directly to the phone (no pc required) and can scan barcodes to search/start downloads. I've seen apps that can do one or the other but it seems like the ultimate would be to do both.
Anything like that out there? A pipe dream still? Sounds like a hell of an idea for a dev out there...
Transdroid is only for remote!
I suggest aDownload. It is still buggy a littlebit and consumes most of the processing power of the phone but still a well-structured, working free app. However, no barcode reader inside..
All the others got limitations such as speed or downloadable number of files.
If anyone got a better suggestion will be welcomed!
I don't think that there are any good bit torrent clients for Android as most of them just control your downloads from your PC.
I use swarm and it works as well as can be expected. Not sure if it scans bar code, but it can be used in conjunction with torrent-fu which does scan (same dev). I have gotten quick replies from dev with any questions. My 2
Good morning,
Does these torrent clients do any caching to minimize writes on flash storage? As you know, flash storage only has a limited number of writes before failure.
Thanks,
