hi guys,
first thread/post. hello to all....
i want to put my tab 2 10.1 tablet into my custom center console. i have a pioneer h/u that has Bluetooth.
i tried doing the Bluetooth but sounds like crap throw my h/u.
tried using the 30pin connector to usb and that does not work.
so right no i have a 3.5 to 3.5 cable to my h/u. it sounds good but its going to be hard to mount this tablet.
as i want to make it removable . was looking for a 30pin to rca but needs to charge from the 30pin connector also. that way i can mount the connector and have my tablet slide in .
is there a 30pin ( for tab 2 ) to rcs / usb cable ???
if not how would you connect the tablet to your radio ?
really want to use the rca input on the back of my h/u to keep it a clean install. as the 3.5 and usb ports are on the front of my h/u .
this is driving me crazy.... if i cant figure this out im just going to get a 10" ipad as there are cables for that tablet. as many people have installed a ipad into there cars/trucks .
and maybe i would get lucky with Bluetooth with a ipad as the h/u manual says you can use ipods with this radio.
but would rather figure out how to install my tab 2 tablet as i already have it.
thanks guys...
thanks guys...
