best way to free up memory? sprint nexus?
You're not suppose to free up memory. Android does that itself the way it's suppose to be done. More free RAM isn't going to increase your performance or battery anyway. Linux based OS, free RAM is wasted RAM. When RAM is needed Android will free it.
Unless of course you are running out of space on your phone
That's a completely different problem.
Can you please be more specific in what your issue is?
weill im running paranoidandroid 4.1.2 rom (thanks to devs.) and i was just trying to see if 245mb (ram) free is normal or bad? i have atleast 24gb free (internal storage).
used a few apps to try to free up space but they really just eneded tasks wich i can easily do with the swipe method (thanks to devs.). is that the normal way to just clear up space and no apps needed?
ty
If you are worried about RAM, see Zeinzu's post. Let Android handle memory management.
Don't worry about ram usage. Your phone takes care of itself. On Linux(and therefore android), empty ram is wasted ram.
Trying to free up more space will do more harm than good
