NuffsaidM8
Just wanted some opinion on a question that has been stifled for a while while I figured things out.
What do you think is the most effective way to go about setting up your layouts?
Do you do all of it with java from the class?
Do you set things up in the XML editor and adjust them with java?
Do you do it all in the XML editor?
Do you do something else?
Any answers are much appreciated.
