Best Word Processor?
radsboy
Member
For a 7" tablet:
What is the best Word Processor that I can type and edit in, and save files as .doc files.
And while I'm at it, what is the best keyboard, e.g one that is most like a computer and has arrow keys for moving around in text without altering it.
Thanks,
R.
I have documents to go, it doesn't do spell check though, it uses the same predictive text as if you were typing in a browser. It does save the documents in the .doc format.
As far as keyboards, are you talking about a virtual or a physical keyboard? If your looking for a physical bluetooth keyboard, you might like the one for the xoom which does have the arrow keys. ;)
I don't know about virtual keyboards because I use the touch screen features to edit or write word documents.
I can't help with word processors but as far as keyboards go it's hard to beat SwiftKey X. I'm pretty sure you can enable/disable arrow keys.
