Better alternative for Doubletwist?
slowmo
hi guys, Is there a music player app other than doubletwist that handles podcasts as well? I used to use Google Music and Google listen separately. It was going well but most of the times when I used the button on the earphone to play music it used to start playing Google Listen as well. Plus I would like to move on from Google Listen and an app that can do both is bonus.
I used DoubleTwist trial version for a while which looked good but it needed me to buy the pro version if I wanted to download podcasts. Now I don
Hey slomo
Why not go to the app market (google play) ans do a search for what you are looking for? What you are looking for will give you a bunch of apps that do whatever your search is asking for. At that point, you can read the user reviews and see which app scores the highest and has the greatest number of users....Hope this helps
