better keyboard app help
gow75
I have the Better keyboard app installed and purchased. how do i enable Swype on it so i when i text i can just swype my finger across the letters to type? :confused:
I'm a newbie so I can't tell you a lot but I will say that I downloaded the trial of Swiftkey and the swype on it is awesome. I'm really amazed at how well it will pick up my gibberish I draw on my keyboard.
I tried A.I. Keyboard as well. That's a pretty good one but I don't think it has swype. I actually like the look of their keyboard better but for the same price as Swiftkey I think I'm going to be purchasing the Swiftkey.
You might uninstall the keyboard you have now and give Swiftkey a try. You might like it better and just take the purchase of the other one as loss to experience.
I have swiftkey and better keyboard. I use better keyboard most of the time though, and I don't care for swype.
I like Better keyboards skins though! but if that is case i will try swift key because im really tired of texts that dont come out correctly.
