Better remote
Savage Shadows
So I've run into a roadblock that could be solved with a simple application. Really, quite simple as long as you know how to build and manipulate a simple server on a Windows PC.
I've used computer remote apps that run different functions from your Android to your PC, and they work great. I've also come across game remote versions of those, and never really had a use. However, I have two MOGA Pro Power remotes which you could consider their usability with a PC abysmal. I was hoping I could map a MOGA over one of the remote gaming controller apps, but they don't support it.
It would be really nice if somebody could program an app that had amazing support for bluetooth gaming controllers on the Android system, that also served as a PC remote for carrying over the inputs to the PC for gaming and emulators. I imagine the hardest part would be the full analog sticks.
Not asking for a miracle, but think it would be great if somebody found the time to make something like this.
