Better way of answering calls ????
acidblue
There has got to be a better way of answering calls than just with a swipe gesture.
If I could 'flip' the phone that would be awesome, but I can't find any settings for that.
Yes I have a hard time with the swipe gesture, I swipe and swipe and it does not answer the call.
I hate automatic answer btw.
If you disable your lockscreen under settings > lockscreen it will disable the swipe to answer when you get a call. But you also disable your lockscreen :/
My Motion is boxed up in drydock but that isn't so on my Spirit anyway. I have no LS and still have to swipe to answer. I sure miss just hitting the answer tab like on my old DroidXs. :( I really don't wanna do the Gangnam shake thing (App) either to answer and it did take me a while to get used to swiping.
Bruce in Ocala, FL
