Big Problem...NO Charger = NO PHONE !!
XxAmRxX
I Have a very big problem with my galaxy ace
as long as the mobile is connected with the charger,everything goes well
but if the charger is not connected,problems begin
1-Cannot Connect to The Internet through WI-FI
2-Bluetooth cant send or recieve files
3-when i play a video,,it makes something like scratches and it goes bad !!
4-MP3 Files..bad sound and as if it is damaged and afterwards it doesnt work any more !!
but if the charger is in..nothing of those problems happen !!
what can I DO ??!!
what can I DO ??!!
Hope you're in the warranty period. Go and replace. :cool:
I totally agree with Babus! The phone "stinks", needs to be replaced.
Buy a new battery or use your warranty if you're not sure what causes the problem. I would use the warranty :)
Warranty Warranty Warranty. Don't try anything else. The phone has to work. Ask for a new phone and battery. Not just one of them.
Thxxxxxxxxx all
I Bought the phone 6 months ago and still 6 months till the period of warranty ends
gonna use my warranty
