I'm going to try to tackle them one at a time, okay?Well there is a long list of problems I have with Android.
Besides this I also have other issues.
Nope. That's simply not true. I have all my Android devices set not to auto-update anything. I get notified when there's an update for something, say a bunch of apps; I look through the list and decide for myself what/whether to update.Like in Windows you can turn OFF auto update.
In Android you can't.
See, that is not an Android problem--it's a user problem. You're blaming the OS for something you've caused. Here's how to fix it:I am forced to having slowdowns when using the internet to downloads updates of Google apps I DON't even use.
- Open the Play Store app.
- Press the menu button (3 bars, top left corner).
- Select Settings.
Do you see what to do next to solve this 'Android problem' that you've been 'forced' to live with?
