1amandroid
I'm running Android ICS and I'm having a lot of problems to sync media with my Mac. Both the Music Library and Photo/Video Gallery are not updating.
For instance, if I add songs to my phone, I can see they're inside and I can open them through a file manager, but I obviously want them to show up in the list of songs of the music library. Same thing if I remove songs, I can see they're not into the phone but they still show up in the library, and if I click on them it says it can't find them...
This happens no matter what app I use. I tried Sony Bridge for mac to sync music, and it doesn't work. I tried doubleTwist which works but only using the doubleTwist player on my phone. Phone's libraries are not updating.
It's really a problem for me, what should I do? I've already tried a Factory Reset, with no success. Switching on/off doesn't work either.
Thanks.
EDIT --- I've just erased my SD card (from my phone) and now everything works fine, I think it was some problem in the cache folders.
Thanks.
