The Samsung mail app does not sync with imap gmail. And the gmail app cannot get rid of conversation mode.
I was using K-9 ....that is until I discovered MyMail (in the Play Store). Absolutely superb email client. Notifications are instantaneos and the graphical layout is gorgeous.Why use either, just grab K-9 Mail from the app store and all those issues go away.
Happy yoiu like it. I tried a few and it was, by far, the best. Kind of surprised it's not more widely used.Thanks for MyMail info
Just solved some major gripes here.
Oh well.
i think your misunderstanding..
when i go to the dialer, i am calling someone.. not texting.. on my HTC, i would start by typing the persons name, lets say.. bobby.. i would type 262, and a list of names would show up.. i could then click his name.. and it dialed him.
on this phone.. i do the same.. his name pops up.. i have to click his name.. his number populates in the really huge number screen.. then click the green call button on the bottom to make the call..
i will give KK launcher a try.. i am really happy with how touchwiz works with launcher seamlessly..
Yes, regarding the contact function, it would be nice in a future release to possibly enable that option "for one click dialing" once you type out and select the contact. much like defaults for which app is used, it would be awesome within certain apps to set a default function.
Can't wait to try mymail, and see how it works. Dont have phone in front of me (at work), but wondering, if I had set up my gmail app, how do i stop notifications from that, or do I just delete that app and disable the stock email app?
On the calling, you can select the function to call the current contact when lifting the phone to your ear. I use it, it works.
For disabling gmail notifications. Go into full settings (single finger swipe, select cogwheel at top), go down to application manager (almost at the bottom), select Gmail, and uncheck the notification box.
For the email, I think what I mean is to just disable it, so it's not downloading email from the server, and taking up space, I already have the notifications off, but if I click on the app, the emails are there.
Is there any reason not to just uninstall the app? I personally like the native gmail app, but if you're going with something else, just take it off the phone.
What's your biggest annoyance with the S5
I've read all that has been written about the good for both the M8 and S5 and I'm undecided.
I'm hoping since I can't decide base on the good features perhaps the bad will help....
