Apps Binder driver protocol does not match
venugopal
hai,
This is venu.I am trying to port android on leopard DM365 ECDK using common 2.6.32 kernel.Booting is successful and after that i am getiing Red ball but not getting android dispaly on the composite monitor.I check the logcat message by installing hello.apk using adb install command, at that time i am getting the following message
I/Process ( 2483): Sending signal. PID: 2483 SIG: 9
D/AndroidRuntime( 2495):
D/AndroidRuntime( 2495): >>>>>>>>>>>>>> AndroidRuntime START <<<<<<<<<<<<<<
D/jdwp ( 2495): JDWP listening on port 8001
D/AndroidRuntime( 2495): --- registering native functions ---
E/ProcessState( 2495): Binder driver protocol does not match user space protocol!
E/ProcessState( 2495): Binder ioctl to set max threads failed: Bad file number
D/AndroidRuntime( 2495): Shutting down VM
D/dalvikvm( 2495): DestroyJavaVM waiting for non-daemon threads to exit
Please give me a solution to rectify this problem...
Thanks in advance..
Welcome to the Android Forums community! Glad you signed up! Feel free to join the conversations! :D
Steven
Perhaps you meant to post this in the Dev section. I'll move it there to help you get your answer.
