Help Bit of help needed using Jorte calendar.....
stevep94
I have just started using Jorte and quite like the look of it but I want to know if I can change the default view once you "click" into it from the main widget view??
Here is my widget as it displays on my phone:
Here is the default view that I've set it to once you select the calendar:
Here is the view changer with the numbers across the bottom and up the right hand side that you can use to alter the size of the view to a single day:
Here is the view I'd like it to default to when I press the main calendar widget:
It would appear I can press on the option to make it view just the one day but I cant see an option to set this as the default and whenever I exit and go back in it goes back to the 2nd screenshot above! :confused:
Does anyone know if it is possible to set the default view as my last screenshot??
Thanks guys.....
Ive gone through all the settings and i dont think you can set it to open up to just the 1 day the best i could get was the 2nd from bottom pic you had then just tap the "1" tab on the bottom left to display that day only
