Bittorrent Client for Android
wu11ie
Hi folks, hope you can help.
I've recently bought an HTC Desire, after leaving my N97 behind.
I used to use symtorrent a lot on the N97, and i need a similar app for my HTC, but what one do i go for ?
I've had a read through the posts but i can't really find the info i'm looking for.
Hope you can help,
Thanks,
Wullie.
I used to use symtorrent on both my N95 8gb and N97... I've just downloaded swarm and it works in exactly the same way as symtorrent..
I'm using ttorrent. Free and you can get it from the market. Personally I don't really like the app. It could be better.
