I've come across a bizarre issue with phone numbers imported from my Outlook calendar and ones I've used without problem on previous handsets.
For example, dialling a UK number from within the UK - +44114123456 as an example - doesn't, although I might have dialled that number and had it on speed dial a hundred times.
So instead I dial it manually - 02071234567.
The number comes up as +1-114-123-456
Try to redial using that number and it won't work as I haven't yet set up international roaming.
What IS going on?
What IS going on?
