The workaround is simple, if not very obvious.After I upgraded v2.3.3, my LG shine plus always black screen (cannot see anything no matter what keys I press). Therefore, I need to unplug the battery and power it up again and again. Does anyone have this problem?
Please help me to figure out this.
Thank you!
1) When the screen goes blank and becomes seeming unresponsive, press and hold the hang-up button for about a minute (or until you see the screen flash.)
2) Release the hang-up button.
3) Press-and-release the home button.
4) You should now be back at your android desktop.
After you do this, the problem should not re-occur, or at least it has not reoccurred for me.*
*Some exploding may occur. May contain nuts. Not for internal consumption. Keep out of reach of Darth Vader. Void where prohibited. Prohibited where void. For internal use only. Not responsible for lost or missing limbs. In case of anger, please direct anger to your nearest anything that is not me. This message brought to you by electrons.
Yeah, my next phone will be from HTC. LG can go **** themselves. Their brand went on on my "DO NOT BUY" list back in July when they postponed the update to September... and then to October... and then when it did finally come out, it was ****tardedly broken. **** LG!
The only way to solve the problem is to leave your wifi turned off unless you are using it. If you don't put you phone to sleep with the wifi on, the problem never happens.
I've had it happen even with wifi off, but it does happen a lot less.
When you check the "turn wifi off when sleeping" or whatever the option says under wifi settings, it helps the problem alot.
Hey Guys, don't waste your time and money to fix this Garbage phone. Go get another phone!!! You will be much happier , for sure!
Interesting find... Might be related to the sync option then! We'll try and deactivate sync to see if it's still causing the issue
