Blinking/Flashing Screen
Hello and welcome aboard. Good question _ and the short answer is "yes" - it's normal behavior for the phone screen to goes off when your face covers the Proximity Sensor -then comes back on when remove ( A proximity sensor is a sensor able to detect the presence of nearby objects without any physical contact. ....).
I hope the above info helps. :) Also, you can stop by your device's support forum for some cool info and tips on your device. You will want to check in to the forum for your specific device model. Select it from the list here and join your device's area of support - where you'll find the other users of the same device love to hang out... and will be the best place to get device specific help.
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
