You also have the option of letting unwanted calls go to voicemail and having the VM automatically deleted all without your knowledge.It will play a message to the blacklisted, "this number no longer in service."
It's not an app but GV is excellent at this. One benefit to using GV is that calls that GV blocks do not count against you. If you use an app to block calls then your device has to receive the call in order for the app to block the call. From a billing perspective you've received that call, if it matters to you.
