Block call&sms for android
hohai161
Hi everyone,
Hope that you all will support me!!!!!!!!!!!!!! :)
You offen received calling or message that make you uncomfortable or annoyed? They can come from telemakers, spammer or other people that you don’t want to answer…
Are you finding someway to block unwanted call or message on you Androi?
Block SMS and CALL Application is the best and fastest way for your problem
Numbers from the blacklist are blocked quietly and without any signs of a call. Whatever you do, you will not be distracted by phone calls or SMS.
This call blocker also has some convenient setting options, such as the ability to block private numbers, or to disable notifications.
Features:
1. Add phone numbers that you want to block in Black list
2. Help you not waste time for the unwanted SMS and CALL
3. Enhanced the number of contacts who can be blacklisted!!
4. Blocking all incoming calls
5. Blocking all incoming SMS
6. Password protection
Strengths:
- Very easily and quickly to use
- Not consume memory or CPU resources
And it's totally FREE
https://play.google.com/store/apps/details?id=hohai.abcd.blockcall.blocksms
