Block Freeze (mmc_read failed) Note 4 (SM-N910F)
Samsung Galaxy Note 4 mmc_read failed
  • Samsung Galaxy Note 4
  • mmc_read failed
Results are only viewable after voting.
Riavvii e Freeze (mmc_read failed) Note 4 (SM-N910F)
Sometimes you spend your savings on buying high-end smartphones and thus have a quality and longevity of the product over time, but it looks like you've been getting more and more ahead of DURATION IN THE TIME! After an upgrade to the version Marshmallow suggested by my note 4 (SM-N910F), I started having problems freeze the screen and restarted. My terminal has a new original samsung battery and does not mount external MicroSD, being out of warranty even though within a few months i have tried factory reset and full reset without any positive results.
To date, the only way to use my out-of-warranty terminal is to install Rom Custom or Lollipop 5.1.1.
Samsung is trying to figure out where the problem is?
After all these "malfunctions" on this terminal what did you decide to do?
I add that I am a Samsung customer for several years, I'm former possessor of notes, note 2, note 3, note 4 ... I did not take note7 for known reasons !.
I just want to understand why my smartphone, like so many others, has decided it will not work anymore!
I've done a petition, maybe it does not work for him, but I try to do it because I'm so sorry for that.
Petition Link
Thank you guys.
