Block numbers....
Greetings all...
I am getting a call from an 801 number non-stop, five times today, for example. It is so annoying and when I pick it up, there is nothing or nobody there (I answered it only once).
Is there a way to block this number from calling me? Or to get it to go directly to voice mail?
Thanks.
PS... Using a MyTouch 3G Slide
well from what I know, i think there are two ways.
Either use google voice, which will give you a different number called your google number, and you can block calls and use their voicemail,
Or you can try searching the market for a call block app.
I got this.... Save the number in question to your contacts of course then go to your contacts select either edit or menu and check the box that says send directly to voicemail....
I created a contact and labeled it 'Junk Calls', and whenever I get an unwanted call, I add the number to that contact, then I set all calls from this contact to go directly to VM. This way if I accidentally block a potentially important number, I'll get a VM and can remove that number from the list. It's worked like a dream for me!
