P
Pete8888
Guest
Good afternoon.
I'm setting up an android device for someone and I want to know if it is possible to block all broadcast SSIDs from showing on the device? Leaving them only able to connect to one router with a hidden SSID.
More details:
In wifi settings there is a list of available networks as well as previously connected networks (not in range). I am trying to set the device up so that the user (and any apps they install) cannot see the list of neighboring SSIDs. They will be connected to one router via a hidden SSID.
Is this possible?
Thank you.
More details:
Is this possible?
Thank you.
