sanchez1980us
Member
I was wondering how to block calls?
Same herethat is awesome!! just learned something new... thanks!
If you log into your account on Sprint's website, you should be able to add phone numbers to block calls, up to 100 now I believe.
After log in, go to "my preferences", then under "limits and permissions", you have links to block voice, texts, and data. Under block voice, you can add up to 100 numbers to block.
This is a recently added feature, so not all reps know about it yet. Hopefully more people will find out about this, through threads like this.I asked Sprint that question more than once, and no one had an answer. I ended up using an app called Easy Filter, to block calls. But they still go to voice mail, and annoy me with a notification tone. I wonder if this blocks them from ever reaching your voice mail in the first place?
Guess I'll try it.
Thanks
let us know.. if it blocks it completely.. with not access to your voicemail
Nicse!..Just tired it, and yes it blocks the incoming number from even going to voice mail!
Takes about 15 minutes for it to go into affect though.
