Help Blocked numbers
  • Start date Start date
A
Android Question
Guest
I accidentally blocked my best friend from messenges. I have a Samsung core prime phone with an Android os. Please tell me how to unblock her!
Go into your messaging app, settings, and check if your friends number is listed in the blocked numbers list
  1. From a Home screen, tap Contacts (located at the bottom).
    If unavailable, navigate: Apps > Contacts.
    These instructions apply to Standard mode only.
  2. Tap the Menu icon
    (located in the upper-right).
  3. Tap Settings.
  4. Tap Call.
  5. Tap Call rejection.
  6. Tap Auto reject list.
  7. If desired, tap Unknown number to reject calls from unknown numbers.
    Enabled when a check mark is present.
  8. View or edit the list as desired.
    • To add a contact or number to the list:
      1. Tap the Create icon + (located at the top).
      2. Enter the 10-digit phone number.
        Alternatively, to add a number from call logs or contact list, tap the Contacts icon
        To refine the block, tap Match Criteria then select one of the following options:
        • Exactly the same as
        • Starts with
        • Ends with
        • Includes
      3. Tap Save (located in the upper-right).
    • To remove a contact or number from the list:
      1. Select and hold the contact or number.
      2. Tap the Trashcan icon (located in the upper-right).
    • To disable a number on the list without deleting it, uncheck the box next to the desired entry.
